laminated neck question....
http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=38099
Author:  Jim_Beam [ Mon Oct 29, 2012 1:36 pm ]
Post subject:  laminated neck question....
I'm still working on my first build, and already thinking about my next. This one has a 5-layer through neck, 3 layers of maple and 2 of walnut. I'd like to get a little fancier on the next.
I've seen some high-end builds where there is a thin white layer between 2 woods. What is this material? Plastic? Where do I get it, and what kind of glue would I use on it?
Thanks for your input.
Author:  Chameleon [ Mon Oct 29, 2012 2:53 pm ]
Post subject:  Re: laminated neck question....
That's typically a thin slice of wood. Plastic isn't well known as a tonewood and I doubt that's what you're seeing. My guess is rock maple.
P S I'm getting ready to do a laminated neck too. Cocobolo and maple.
Author:  Jim_Beam [ Mon Oct 29, 2012 3:13 pm ]
Yeah, I didn't think plastic would be a good idea. It's just that some of them are so light-colored.
Sweet. My next will be maple, padouk, and walnut. And maybe some pear veneer if it's light enough.
Author:  Mattia Valente [ Tue Oct 30, 2012 5:31 am ]
Maple would be my guess (veneer), although fish paper might theoretically be possible (Stuff binding is made of sometimes).
Author:  Fred Tellier [ Tue Oct 30, 2012 7:36 am ]
Get some veneer, maple or other light colored wood. There is also white fiber sheets available.
Fred
Author:  SteveSmith [ Tue Oct 30, 2012 8:03 am ]
I use maple veneer, as others suggest. Cheap enough and easy to get. I also use it under head plates and such.
Author:  Barry Daniels [ Tue Oct 30, 2012 10:59 am ]
If it is really white then it could be holly veneer.
Author:  Rodger Knox [ Tue Oct 30, 2012 11:08 am ]
I've used holly quite a bit. It can be bright white and look like plastic, especially under finish. Maple usually has a liittle color, esspecially under finish.
Author:  Jim_Beam [ Tue Oct 30, 2012 4:00 pm ]
^^^^ this
Did some Googleing and found affordable holly veneer at CertainlyWood. http://www.certainlywood.com/index.cfm
Ordered up enough to last the rest of my life for $25.
